nfs4 Guest
about this program |
Posted: Wed May 12, 2004 7:11 am |
#include <16F876.h>
/* Set configuration bits in the PIC processor */
#fuses XT, NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
//crystal, no watchdog timer, no low programming, no powerup timer, noprotect=memory protection off
#device adc=10
#device *=16
#use delay (clock=4000000) /* sets appropriate compiler constants 1µsecond instruction cycle */
#use standard_io ( a )
#use standard_io ( b )
#use standard_io ( c )
#define led1 PIN_A1 //led jaune commutateur '0'
#define led2 PIN_A2 //led verte commutateur '0'
#define led3 PIN_A3 //led rouge commutateur '0'
#define led4 PIN_A5 //led jaune commutateur 'R'
#define led5 PIN_B0 //led verte commutateur 'R'
#define led6 PIN_B1 //led rouge commutateur 'R'
#define led7 PIN_B2 //led jaune commutateur '+'
#define led8 PIN_B3 //led verte commutateur '+'
#define led9 PIN_B4 //led rouge commutateur '+'
#define led10 PIN_B5 //led jaune commutateur '-'
#define led11 PIN_B6 //led verte commutateur '-'
#define led12 PIN_B7 //led rouge commutateur '-'
#define Vpp 1024 //seuil maxi de tension
#define Vppfluct 1003 //seuil autorisé de fluctuation de la tension
#define Vppmin 973 //seuil pour lequel la tension est passée du niveau haut à un niveau plus bas*****
#define Vss 0 //seuil minimal de tension
#define Vctq 921 //seuil de chute de la tension
#define tension_maxi_touche_0 34
#define tension_mini_touche_0 0
#define tension_maxi_touche_R 790
#define tension_mini_touche_R 750
#define tension_maxi_touche_plus 523
#define tension_mini_touche_plus 463
#define tension_maxi_touche_moins 287
#define tension_mini_touche_moins 245
#define txPC PIN_C6
#define rxPC PIN_C7
#use RS232(BAUD=9600,BITS=8,XMIT=PIN_C6,RCV=PIN_C7)
#bit ADFM_BIT=0x9F.7
#bit PCFG3_BIT=0X9F.3
#bit PCFG2_BIT=0X9F.2
#bit PCFG1_BIT=0X9F.1
#bit PCFG0_BIT=0X9F.0
#byte INTCON = 0x0b //registre des interruptions
#byte PIE1 = 0x8c //registre contenant les autorisations d'interruptions
#byte PIR1 = 0x0c
#byte ADCON0 = 0x1f //registre du convertisseur
#byte ADCON1 = 0x9f //rôle des pins+justification du resultat de la conversion
#byte ADRESH = 0x1e
#byte ADRESL = 0x9e
#byte port_b = 0x06
#byte port_c = 0x07
#bit GO_DONE = ADCON0.2
#bit ADON = ADCON0.0
#bit ADIE = PIE1.6
#bit ADIF = PIR1.6
#define SET_TRIS_A = 0b00001; // PORTA AN0 entrée et les autres en sortie
#define SET_TRIS_B = 0x00; // PORTB en sortie
#define TMR1IE = PIE1.0
#define TMR1IF = PIR1.0
int16 ADCvaleur;
long ADCvtot;
long Counter1;
int8 Counter2=99;
int8 counter3 =499;
int8 cnt;
#int_TIMER2
TIMER2_isr()
Counter1++;
ADIF=0;
void InitialiseADC ()
setup_port_a( RA0_ANALOG );
setup_adc( ADC_CLOCK_DIV_8 );
set_adc_channel( 0 );
delay_us(10);
#int_rtcc
isr()
cnt++;
void main( void )
long ADCvaleur;
long ADCvtot;
OUTPUT_B(0x00);// clear all pins on port b
ADCON0=0x81; // fosc/32, RA0, a/d off, a/d operating
ADCON1=0x8E; // an0 is a/d input, rest port a digital, internal ref, right justified
INTCON=0xc0; // enable global interrupts and peripherals
InitialiseADC();
if (ADIF=1)
ADIF = 0;
ADCvaleur = 0;
ADCvtot = 0;
setup_timer_2(T2_DIV_BY_4,5,5);
ADCvaleur=read_ADC();
Counter1=0;
while (Counter1<19999)
if (ADCvaleur>Vppfluct)
output_high (led1);
if (ADCvaleur=Vppfluct)
output_high(led5);
delay_ms(2500);
disable_interrupts (INT_TIMER2);
delay_ms(10);
if ((ADCvaleur<=tension_maxi_touche_0) && (ADCvaleur>=tension_mini_touche_0))
output_high(led6);
setup_counters(RTCC_INTERNAL, RTCC_DIV_2);
enable_interrupts (INT_RTCC);
enable_interrupts ( GLOBAL );
set_rtcc (216);
do
ADCvaleur = Read_ADC(); /* read the ADC */
ADCvtot += ADCvaleur; /* add it to total, for later averaging */
while ((cnt<=counter3) && (ADCvaleur<=tension_maxi_touche_0) && (ADCvaleur>=tension_mini_touche_0)); /* increment count, is it ten counts yet? */
disable_interrupts (INT_RTCC); /* don't allow interrupts */
ADCvtot /= 500; /* division par 500 échantillons pour calculer la moyenne des tensions relevée */
if ((ADCvtot<=tension_maxi_touche_0) && (ADCvtot>=tension_mini_touche_0))
continue;
output_high(led3);
setup_timer_2(T2_DIV_BY_4,10,5);
if (ADCvaleur == ADCvtot+ADCvtot*0.1)
output_high(led7);
delay_ms(2500);
disable_interrupts(INT_timer2);
delay_ms(20);
counter1=0;
setup_timer_2(T2_DIV_BY_4,15,5);
do
output_high(led2);
while ((ADCvaleur>=Vppfluct) && (counter1=199));
output_high(led3);
output_high(led3);
if ((counter1++==19999)&&(ADCvaleur>=Vppfluct))
output_high(led3);
output_low(led1);
it seems to be some bugs or mistakes on this program?
sone help me plz |
Neutone
Posted: Wed May 12, 2004 7:59 am |
When you have a problem thats too big to solve you have to break it into smaller parts. For example you know that you are getting good results from everything but the output pins. Write a simple program to toggle the output pins. Build on it one piece at a time until you are back at the program you have now. That way you will know where you it broke. |
