Mc
I2C SW working... I2C HW don´t? |
Posted: Fri May 07, 2004 6:26 am |
Hi guys! I'm new to CCS C and I'm having some trouble getting the I2C HW working...
If I use #use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3) it works OK:
Program running
I2C init ok
Write: 00 02 04 06 08 0A 0C 0E
Read: 00 02 04 06 08 0A 0C 0E
but when I force HW I2C instead with #use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,force_hw) it gets stuck:
Program running
I2C init ok
Here's my sample code, I use routines from 2465.C with some changes to fit my needs:
Code: | #include <16F876.h>
#fuses NOWDT,XT,NOPUT,NOPROTECT,BROWNOUT,NOLVP,NOCPD,NOWRT,NODEBUG
#define EEPROM_SCL PIN_C3
#define EEPROM_SDA PIN_C4
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
//#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,FORCE_HW)
#define hi(x) (*(&x+1))
void i2c_init (void)
output_float(EEPROM_SCL);
output_float(EEPROM_SDA);
int1 i2c_device_ready (int8 i2c_slave_address)
int1 ack;
i2c_start(); // Si se admite petición de escritura entonces
ack = i2c_write(i2c_slave_address); // el dispositivo está listo
i2c_stop();
return !ack;
void i2c_buffer_write_16 (int8 *i2c_buffer, int8 i2c_slave_address, int16 address0, int8 i2c_data_number)
int8 i;
while(!i2c_device_ready(i2c_slave_address));
i2c_start();
i2c_write(i2c_slave_address); // controlbyte (write)
i2c_write(hi(address0));
i2c_write(address0);
for(i=0;i<i2c_data_number;i++) i2c_write(i2c_buffer[i]);
i2c_stop();
void i2c_buffer_read_16 (int8 *i2c_buffer, int8 i2c_slave_address, int16 address0, int8 i2c_data_number)
int8 i;
i2c_start();
i2c_start();
i2c_write(i2c_slave_address+1); //controlbyte (read)
for(i=0;i<i2c_data_number-1;i++) i2c_buffer[i]=i2c_read(); //n-1 data->read+ack
i2c_buffer[i2c_data_number-1]=i2c_read(0); //last data->read+noack
i2c_stop();
#define I2CREGS 8
int8 i;
int8 i2c_buffer[I2CREGS];
for (i=0;i<I2CREGS;i++) i2c_buffer[i]=2*i; //0,2,4,6,8,10,12,14
setup_adc_ports(RA0_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_256);
setup_timer_1(T1_DISABLED);
printf("Program running\n\r");
i2c_init();
printf("I2C init ok\n\r");
i2c_buffer_write_16(i2c_buffer,0xA0,0x00,I2CREGS);
printf("Write: ");
for(i=0;i<I2CREGS;i++) printf("%X ",i2c_buffer[i]);
printf("\n\r");
i2c_buffer_read_16(i2c_buffer,0xA0,0x00,I2CREGS);
printf("Read: ");
printf("\n\r");
I'm using an 16F876 @ 4MHz, CCS v3.187 and I'm testing the I2C with a 24LC64 EEPROM...
Any idea??
Thanx in advance ![Wink](images/smiles/icon_wink.gif) |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Fri May 07, 2004 6:47 am |
Make sure RC3 and RC4 are configured as inputs. Have you tried taking the 'fast' keyword out to see if it works? How big are your pull-ups? |
Mc
Posted: Fri May 07, 2004 7:24 am |
Thanx for the quick answer!
Manually setting PORTC as inputs with set_tris_c(0xFF); doesn't solve the problem, maybe RS232 routines are overwiting this setting??
My pull-ups are 2k2 each. In 'Slow' mode it doesn´t work either.
Also I think that I don't have to output float the i2c pins while using i2c hw, I tried to comment
but still no luck...
I guess there's no HW related problem since I've been working with I2C HW ASM routines in the same board not so long ago with no issues whatsoever... |
Posted: Fri May 07, 2004 12:06 pm |
I would guess that you're probably using PCW.
If you don't use a peripheral module, PCW puts in code to
explicitly disable it. This isn't really necessary, because the
peripheral modules are disabled by default upon power-up.
The problem is caused by this line of code:
setup_spi(FALSE);
That line sets the SSPCON register to 0x00. So it affects
the entire SSP module, and not just "spi", as the function name
suggests. It writes a 0 to the SSPEN bit in that register.
According to the data sheet:
bit 5 SSPEN: Synchronous Serial Port Enable bit
0 = Disables serial port and configures these pins as I/O port pins
That's why it's not working. The solution is to delete that line. |
kender_a Guest
Same problem. |
Posted: Fri May 07, 2004 2:22 pm |
I have the same problem - I2C stops worling if is specify FORCE_HW. But I don't have a call to setup_spi() anywhere in my code. Here's my code:
#include <18F442.h>
#device ICD=TRUE
#device adc=8
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, DEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(DEBUGGER)
#use i2c(Master,sda=PIN_C4,scl=PIN_C3,force_hw)
#include "i2ctest.h"
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
while (1)
// single write to EEPROM
i2c_start();
i2c_write(0b10100000); // command byte
i2c_write(0x01); // address
i2c_write(0xAA); // data
i2c_stop();
// single read from EEPROM
i2c_start();
i2c_write(0x01); // read address
i2c_start();
i2c_write(0b10100001); // command byte
printf("%4X\n\r", i2c_read(1)); // end of the read
i2c_stop();
// page write to EEPROM
// page read from EEPROM
// write to DAC
// read RTC
I'm running this with the debugger, and the execution halts at "setup_adc_ports(NO_ANALOGS);"
What am I doing wrong?
Nick |
Posted: Fri May 07, 2004 2:33 pm |
Quote: | I have the same problem - I2C stops working if I specify FORCE_HW |
Quote: | I'm running this with the debugger, and the execution halts
at "setup_adc_ports(NO_ANALOGS);" |
These are two separate complaints. I'll answer the one about
the i2c problem.
You have this line of code:
That's wrong. The last i2c read must do a "NAK".
It should be:
printf("%4X\n\r", i2c_read(0)); |
kender_a Guest
NACK worked |
Posted: Fri May 07, 2004 2:52 pm |
Thanks, switching to i2c_read(0) worked, and formware doesn't halt at setup_adc_ports(NO_ANALOGS) too.
I have another question though. I have to pause for about 5ms between the read and the write. Otherwise I read 0xFF. Can this pause be avoided? Here's my code again:
while (1)
i2c_start();
i2c_write(i); // data
i2c_stop();
delay_ms(5);
i2c_start();
i2c_start();
printf("%4X\n\r", i2c_read(0)); // end of the read, NACK
i2c_stop();
// write to DAC
// read RTC
++i;
if (i == 255) i = 1;
Posted: Fri May 07, 2004 3:21 pm |
Quote: | I have another question though. I have to pause for about 5ms
be avoided? |
The EEPROM data sheet will tell you that it takes about 5 ms for
the write operation to be completed. Look at page 4 of the
data sheet, at Parameter No. 17:
http://ww1.microchip.com/downloads/en/DeviceDoc/21203l.pdf
The two common ways to handle this are:
1. Put a delay_ms(5) statement at the end of the write operation.
ie., put it after the i2c_stop() statement at the end of the routine.
(Or use a slightly larger delay, such as 6 ms, to be extra safe).
2. Do "ack polling". This method is discussed in the 24LC256 data
sheet. CCS does this in their sample EEPROM drivers.
The drivers are in this directory:
c:\Program Files\Picc\Drivers
If you have the demo, you probably don't get these files. |
dyeatman
I2C Delay Required |
Posted: Fri May 07, 2004 3:38 pm |
One way to eliminate the delay is to use FRAM which does not require a delay between the write and read.... |
Mc
Posted: Fri May 07, 2004 9:46 pm |
PCM programmer wrote: | The problem is caused by this line of code:
setup_spi(FALSE);
Yep, that was the problem!
Thanx a lot!! ![Wink](images/smiles/icon_wink.gif) |
hayri Guest
Posted: Sat Mar 19, 2005 9:53 am |
very old topic to post. but i must!
thanks a lot PCM programmer it solved my problem. |
