Unexpected Result using 16F84...Please review
Guest_X44
PostPosted: Mon May 03, 2004 5:42 pm     Reply with quote
I'm trying to read a single switch using a 16F84.
As you can see in the code below I'm only sending 2 bytes of data if the state
of the switch changes.
However, I'm getting the following 3 bytes:
If RB6 is LOW, it sends: 0xFE 0x1E 0x00
If RB6 is High it sends: 0xFE 0x9E 0x00
I was expecting the following:
If RB6 is LOW, it sends: 0xBF 0x01
If RB6 is High it sends: 0xBF 0x00
The variables nTemp and nFinal holds the polled and valid state of the switch, respectively.
The MSB represents the switch state, and the 2 LSB is the counter.
I know something is wrong here. Perhaps, people in this forum can help me on this. Thank you in advance.
I'm using CCS 3.173
Also, I'm not using a max232, hence, an INVERT parameter in the #use rs232.
#include <16f84.h>
#fuses HS, PUT, NOWDT
#use delay (clock=10000000)
#use rs232 (baud=9600, xmit=PIN_A0, rcv=PIN_A1, INVERT)
//declarations
#define  COUNTER     0x03
#define  BOARD_ID    0xBF
int nTemp, nFinal, buf, z;
void get_input(void);
void send_out(int, int);
main()
   get_input();
   nFinal = nTemp |  COUNTER;
   buf = nFinal;
      if( (nTemp & 0x80) != (nFinal & 0x80) )
         nFinal--;                                  //state changed, so decrement counter
         delay_ms(5);
         if( (nFinal & COUNTER) == 0x00 )           //counter now zero?
            z = (nTemp == 0x80) ? 1 : 0;
            nFinal = nTemp | COUNTER;               //store final state
       buf = nFinal;                           //make a copy
            send_out(BOARD_ID, z);
            nFinal = buf;                           //no change, so restore previous valid state
      get_input();
   if(input(PIN_B6))
      nTemp = 0x80;
      nTemp = 0x00;
void send_out(int board_ch, int value)
   putc(board_ch);
   putc(value);
Guest_X44
PostPosted: Mon May 03, 2004 6:15 pm     Reply with quote
I got it.
Thanks anyway.
