AllanL5
Posted: Tue Apr 27, 2004 3:49 pm |
In Radio transmission, you CAN'T transmit a DC component -- you can only transmit AC signals. Also, when you capacitively couple signal stages, any DC component will be lost. This will result in a distorted data signal. Manchester encoding gets around all this.
Another way around it is to have a 'HIGH' signal produce one tone, and a LOW signal produce another tone. The tones have no DC component either, so get around the DC component limitation. This is how modems work on telephone circuits.
The easiest way to get two PIC's to talk to each other is through some RS232 port use. Signal at 0 to 5 volts, and you won't even need a MAX232 driver chip.
For distance (300 feet) you can use the MAX232. For longer distance (4000 feet) you can use RS485 drivers. |
