Bug: Int16 overwrites data in call by reference
PostPosted: Fri Apr 23, 2004 5:49 am     Reply with quote
Just for your info: I reported a compiler bug in PCH v3.187. When incrementing a 16 bit integer and assigning the result to a referenced int8 variable, other data is overwritten.
#include <18F458.h>
#fuses HS,NOWDT,OSCSEN,PUT,BROWNOUT,NOLVP
#use delay(clock=16000000)
#use rs232(baud=38400, parity=N, xmit=PIN_D1, rcv=PIN_D0)
#separate void Test(int8 &A, int8 &B)
  int16 C;
  B = 1;
  C = 2;
  A = C + 1;     // High nibble of result overwrites B !!!
  int8 A, B;
  Test(A, B);
  printf("A= %d\n\r", A);   // A= 3
  printf("B= %d\n\r", B);   // B= 0    ERROR, must be 1 !!!
A workaround is:
Change
A = C + 1;
to:
A = (int8)C + 1;
It's a bug and at least the compiler should have issued a warning.
Re: Bug: Int16 overwrites data in call by reference
PostPosted: Fri Apr 23, 2004 5:57 am     Reply with quote
#include <18F458.h>
  int16 C;
  B = 1;
  C = 2;
  int8 A, B;
  Test(A, B);
A workaround is:
Change
A = C + 1;
to:
A = (int8)C + 1;
I'm not suprised.
CCS, is _very_ loose about types of pointers. It can be useful (allowing you to pass an integer pointer, and then using this to address other data). As you say, the compiler should really just 'warn' that the operation is producing a type larger than the data type defined in the function call. Many people have in the past used other C 'syntax checkers', to scan code before compiling with CCS, to trap exactly this type of problem.
guest
type casting
PostPosted: Sun Apr 25, 2004 8:21 pm     Reply with quote
Another workaround is:
Change
A = C + 1;
to:
C = C + 1
A = C;
However, explicit type casting is prefered for the _loose_ CCS compiler.
PostPosted: Mon Apr 26, 2004 7:42 am     Reply with quote
I'm positively surprised by the quick response from CCS:
"The problem you reported has been fixed and will be in the
next compiler release."
(current version = 3.190).
