!Help! RS232 OERR ERRORS
ccarty
PostPosted: Tue Apr 20, 2004 11:59 am     Reply with quote
Crying or Very sad I am using the #USE RS232 pre-processor directive as follows.
#use rs232(baud=9600,xmit=PIN_B2,rcv=PIN_B1,bits=8,parity=N,errors)
This is on a pic16f648A, using the hardware usart.
My question is:
When errors is added as an option, are both framing and overun errors cleared automatically?
I think that I have been able to create an OERR and it does not appear that it was cleared.
Thanks for your help.
PostPosted: Tue Apr 20, 2004 12:05 pm     Reply with quote
What is your version of the compiler ?
Look at this thread in the archives. If you have the same
problem, you may have to email CCS for a solution.
http://www.ccsinfo.com/forum/viewtopic.php?t=17251&highlight=16f648a
ccarty
PostPosted: Tue Apr 20, 2004 1:16 pm     Reply with quote
PCM compiler version 3.184 ........the project compiles fine. I am questioning whether or not the OERR error is cleared automatically or if I need to check/clear it manually.
PostPosted: Tue Apr 20, 2004 1:34 pm     Reply with quote
I did a test compile with PCM vs. 3.184 for the 16F648A, and it
does generate code for the hardware USART. So that's OK.
Here is the generated code for the CCS library routine "getch".
It shows that they do check the OERR bit, and if it's set, they
clear it by toggling the CREN bit (per the data sheet).
0004:  BTFSS  PIR1.5
0005:  GOTO   004
0006:  MOVF   RCSTA,W
0007:  MOVWF  rs232_errors
0008:  MOVF   RCREG,W
0009:  MOVWF  @78
000A:  BTFSS  rs232_errors.1    // Test the OERR bit
000B:  GOTO   00E
000C:  BCF    RCSTA.4           // If OERR = 1, then toggle CREN
000D:  BSF    RCSTA.4
000E:  NOP
000F:  BCF    PCLATH.3
0010:  GOTO   020 (RETURN)
PostPosted: Tue Apr 20, 2004 1:41 pm     Reply with quote
thanks for your help...
