max transfer rate on PIC16C765 via USB
Tsif
PostPosted: Wed May 05, 2004 6:55 am     Reply with quote
Does anyone know the maximum trasfer rate between the PIC16C765 and a PC via the USB? Can a transfer rate of 16Kb/sec be achieved, and if not what is the maximum?
Thanks in advance
Kasper
PostPosted: Wed May 05, 2004 10:10 am     Reply with quote
I suppose that depends on what you do with the data transferred. I have a 18f6620, which I communicate with through a FTDI USB chip @38400bps
I have a 6MHz crystal, which is not liking much higher baud rates without errors.
On my project, the limiting factor is not the serial transfer as much as it is writing the data to an I2C EEPROM.. saving straight to RAM, you should really not run into any problems.. especially at 16Kbit
Darren Rook
PostPosted: Wed May 05, 2004 12:22 pm     Reply with quote
PIC16C7x5 can only use slow speed, which means there is 10ms between each transaction. A transaction is one packet. The max packet size for slow speed devices is 8bytes.
So 8bytes every 10ms = 800 bytes a second
Kasper
PostPosted: Wed May 05, 2004 12:45 pm     Reply with quote
My bad.. I was thinking it was a regular PIC Embarassed
