simple switch thru serial port? |
Posted: Thu Apr 15, 2004 5:40 am |
Is it possible to connect a simple switch through the serial port without using any active components? If so, which pin/s and how should it be done? |
Humberto
Posted: Thu Apr 15, 2004 6:32 am |
This was done several years ago !!!
http://lcweb2.loc.gov/ammem/atthtml/mrshome.html
Pls explain your application with more details
Humberto |
Posted: Thu Apr 15, 2004 7:43 pm |
We simply just want a single switch connected to the PC. At the moment we use the game port and use it just for the switch - quite expensive!
We don't want to design a board just for this simple application. We want to cut down on costs.
Imagine having over 100 PCs having a games card for each one. It's too costly.
The PCs will run ca ustom application but require a footswitch connected to each one. |
For Humberto |
Posted: Sun Apr 18, 2004 2:04 am |
Could you, or anyone else help me on this query. |
Humberto
Posted: Sun Apr 18, 2004 6:59 am |
Hi Guest(???)
This forum is related to PIC microcontrollers and CCS C Compiler.
The info you are looking for, will be find it in hundreds of sites like:
http://www.reviewcentre.com/reviews32234.html
http://www.lvr.com/parport.htm
It's a matter of kindless but I would prefer you log in to know with whom I'm talking to.
Best regards,
Humberto |
