xav27 Guest
Help me Can't programm PIC16F877 with ICD-S |
Posted: Wed Apr 14, 2004 4:03 am |
Hello everybody,
I'm using PCW V3.187, ICD-S and PIC16F877-20/L
I just can't programm the chip using ICD-S :
After a "Download to Target" a window popup and says "Verification Result" all address are read 3FFF.
Configuration Fuse Actual : 7E 3E and should be 7E 3F !?
CPD is unchanged.
If I erase the chip and then Read Device Configuration the result is FF 3E
( RC,WDT,NOPUT,NOPROTECT,BROWNOUT,LVP,CPD,NOWRT,NODEBUG)
Here is my little test programm :
#if defined(__PCM__)
#include <16F877.h>
#fuses HS,NOLVP,NOCPD
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7, PARITY=N)
main() {
puts("\r\n");
printf("Test PIC16F877 Date : ");
puts(__DATE__);
while(TRUE);
What is goin wrong ?
Can anyone help me ?
Thanks in advance
Xavier |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Wed Apr 14, 2004 6:31 am |
3FFF indicates a blank chip. Make sure all the connections from the ICD to your chip are correct. |
xav27 Guest
Posted: Wed Apr 14, 2004 7:12 am |
Thanks Haplo,
It was just because I had Vcc too low ....
Sorry for all
Xavier |
