Pointers to high banks?
guest
PostPosted: Mon Apr 26, 2004 11:52 pm     Reply with quote
I'm struggling to understand how CCS handles pointers...
I want to set up a pointer to some device registers in Bank3. When I look at the generated code, it seems to use only 8-bit pointers, ignoring the higher bits of the pointer and not setting the bank select bits in the STATUS register.
What am I doing wrong? This is an eg...
#byte      a_reg = 0x1a0
unsigned char buffer[8];
function() {
    int i = 0;
    unsigned char * Ptr = &a_reg;
    while(i<8) {
      buffer[i++] = *Ptr++;
When I look at similar code, it only use 8 bits for the pointer, clearly accessing bank 0, not bank 3.
Clues? Help?
Thanks.
Haplo
PostPosted: Mon Apr 26, 2004 11:58 pm     Reply with quote
Add this line to your code:
#device *=16
It tells the compiler to use 16 bit pointers (for 14 bit parts).
Jeprox
PostPosted: Wed Apr 28, 2004 9:54 pm     Reply with quote
In addition to Haplo's answer initialise the pointers inside main() as well.
