RainerGund
Joined: 15 Oct 2003 Posts: 1 Location: Wiesenbach, Germany
Optimization levels |
Posted: Wed Mar 31, 2004 12:50 am |
is there any further explanation about the functionality of the different optimization levels ?
Will it have any effect on code or memory size by changing it on the same source code ?
Tanks
R.Gund |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Wed Mar 31, 2004 2:23 am |
Yes it does have big effects on the code/memory size. I've experienced size differences up to %10 between #opt 0 and #opt 9 on the same source code. |
ajt
Optimization Levels |
Posted: Wed Mar 31, 2004 11:19 pm |
Not clear why one would ever want to set a low optimization level unless this directive is the same as "bug threshold" (or inverse thereof). The manual says that the directive "may also be used if an optimization error is suspected"!
So how is one to know what to use so as to not incur latent bugs!?! _________________ Al Testani |
regan
Joined: 10 Sep 2003 Posts: 5 Location: Wellington, New Zealand
Optimisation Levels |
Posted: Thu Apr 01, 2004 2:28 am |
The optimisation levels are important to me at the moment as there is a bug in some of the RAM addressing in the most recent version of the PCH compiler. To get around it I need to set the opt level to 5 which uses 'conservative' switching of RAM banks. This has the undesirable effect of increasing my code size by over 12%. Meanwhile, I still have useable code until CCS find time to fix the bug. Normally, I would set the opt level to as high as possible.
Regan. |
