I have an application using 16F877 with both I2C component and another PIC on SPI. Both functions are multiplexed on the same pins.
pin/SPI/I2C
RC3/SCK/SCL
RC4/SDI/SDA
RC5/SDO
Is it possible (electronically) to connect both on the same pin and communicate individually (of course one at a time)?
The reason for SPI to another PIC is that 16F877 UART is connected to modem. Besides using a software async to communicate with the second PIC, is there a better way?
Thanks in advance.
-- DJP
Jos
Posted: Sat Mar 27, 2004 11:47 am
Why not use a software SPI-function in your program? It work's fine for me!
Jos
djpark
Posted: Sat Mar 27, 2004 12:56 pm
Jos
Thanks for the suggestion.
Do you mean s/w-SPI on the master PIC to communicate with slave PIC?
How stable is it? Is there a sample from CCS or example to point to?
Thanks.
-- DJP
Neutone
Posted: Sat Mar 27, 2004 1:38 pm
You can dynamicaly reconfigure the port. I don't know what problems you will have but it can be multiplexed.
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
