Joined: 09 Aug 2004 Posts: 7 Location: Kensington, MD
Any body (succesfully) using A to D on 18F4620
Posted: Wed Sep 08, 2004 2:59 am
I am having a problem getting the A to D converter do a conversion accurately. It appears that the compiler is generating code is masking the reading to 8 bit instead of 10 bits. for instance I get a reading of 110 instead of 604.
Any suggestions?
Charles Stieff
Mark
Posted: Wed Sep 08, 2004 6:11 am
Are you using the #device ADC=10 ?
Is your result a 16bit variable? int16?
