#define to a pin and testing to a variable
Jim McBride
PostPosted: Wed Mar 24, 2004 3:06 pm     Reply with quote
I have not been able to search out and answer in the list.
I have defines set to input pins. But when I try and test on those against int sized variables the results are not what I expect. Is my problem testing a bit against a byte even if the byte is a 1 or 0? Do I have to make a bit variable for testing? Am I being grossly ignorant?
#define Trig_source PIN_D0
int internal = 1;
if(Trig_source == internal)
run_internal();
When PIN_D0 is set high(simulated), the IF statement will never test true.
Thanks,
JIMc
PostPosted: Wed Mar 24, 2004 3:51 pm     Reply with quote
Use the input() function to read the pin. Then test the value
returned by that function.
Jim McBride
PostPosted: Wed Mar 24, 2004 4:22 pm     Reply with quote
OK will do. The #define seems to work fine for outputs. Not sure why I was expecting a variable to automatically grab an input from a port. wishful thinking...
Wanting to keep the code readable, the following works fine:
int internal = 1, external = 0;
if( input(Trig_source) == internal )
run_internal();
Thanks for the help!!
