Michaelc
Find start address of functions |
Posted: Tue Mar 16, 2004 6:38 am |
Hey
i currently working on a project where i need to find the start address of functions. The easiest way would be to use function pointers however iam stuck with the older versions of the ccs compiler. However i have wrote a program whhich searches for a string in a function where the start of the string is at the start address of the function, this works fine but i can run in to some problems due to how the compiler works, for example sometimes it puts some operations in before the string therefore making my program useless, i was wondering if there is another way i could handle this problem.
void taskA()
char string[12] = "TASK_FIND_A"; //SEARCH STRING
The above shows the format of the functions i need to find, if i for example put in a printf statementm the compiler does something weird (in the symbols file it doesn't seem to have compiled the function) which i can't understand and makes the search string program useless
void taskA()
printf(lcd_putc, "%c", char_in);
can anyone tell what is happening here?
Michael |
Posted: Tue Mar 16, 2004 11:27 am |
Well, you didn't say what version of the compiler you have,
so I'll assume that by "older" you mean vs. 2.7xx.
In the example below, I used PCM vs. 2.734. I used #org
statements to set the starting address of two sample functions.
Code: | #include <16F877.h>
#use delay(clock = 4000000)
#org 0x200, 0x2FF
void func1(void)
char c;
c = 0x55;
#org 0x300, 0x3FF
void func2(void)
char i;
i = 0xAA;
func1();
func2();
This code produces the following .LST file, which puts the
start of the functions at the specified addresses.
.................... void func1(void)
.................... char c;
.................... c = 0x55;
0200: MOVLW 55
0201: MOVWF 21
0202: BCF 0A,3
0203: BCF 0A,4
0204: GOTO 00C
.................... #org 0x300, 0x3FF
.................... void func2(void)
.................... char i;
.................... i = 0xAA;
0300: MOVLW AA
0301: MOVWF 21
0302: BCF 0A,3
0303: BCF 0A,4
0304: GOTO 00D
.................... void main(void)
0004: CLRF 04
0005: MOVLW 1F
0006: ANDWF 03,F
0007: MOVLW 9F
0008: MOVWF 04
0009: MOVLW 07
000A: MOVWF 00
.................... func1();
000B: GOTO 200
.................... func2();
000C: GOTO 300
.................... while(1);
000D: GOTO 00D
000E: SLEEP |
