Vovachess
problem with const |
Posted: Mon Mar 15, 2004 1:32 am |
I just started with CCS and got confused with this code
char const send_clientlogin[]= "clientlogin";//--Ichip variable, login of client
char const send_clientpassword[]= "clientpassword";//--Ichip variable, password of client
char const send_turnon[]= "turnon";//--Ichip variable, turn on the power flag
char const send_workaddtime[]= "workaddtime";//--Ichip variable, continue working mode of the server flag
char const send_clientpasswordflag[]= "clpwop";//--Ichip variable, enable/disable client login and password flag
char const send_clientpageflag[]= "clientpageflag";//--Ichip variable, client page flag
void test (char arr){
printf("AT+I%S\n\r",array);
main {
test (send_clientlogin);
I have a lot of constants strings that I define in ROM. How correctly send ROM constants as a parameter to the function.
When I define so
char send_clientpageflag[]= "clientpageflag";//--Ichip variable, client page flag
main {
test (send_clientpasswordflag);
test (send_clientpageflag);
The function with const doesn’t work right. What’s a problem and how to be in this case?
thanks |
Posted: Mon Mar 15, 2004 3:01 am |
I found That theres no support of dirrect adressing to ROM very bad
I have a lot of daclaration of CONST in ROM and I need to send them to RS232 a lot of times in different part of program
So I do in this way
char code send_clientpageflag[] ="blablabal";
char code send_empty_line[] ="xxxxxxl";
printf("AT+I%S='%S'\n\r",send_clientpageflag,send_empty_line);
or
in this way
strcpy(arr1,send_clientpasswordflag);
strcpy(arr2,send_a);
send_ATComm(arr1,arr2);
where
void send_ATComm(char array1,array2){
while (timed_getc(500)!=0x87);
printf("AT+I%S='%S'\n\r",array1,array2);
both solution gave me a lot of extra code. Till 10KB!!!!
I used Keil for Atmel and I have no problem with ROM adressing!!!
Is there any optimasation |
Posted: Mon Mar 15, 2004 4:43 am |
Anonymous wrote: | I found That theres no support of dirrect adressing to ROM very bad
So I do in this way
or
in this way
where
Yes.
If you only want to 'send' the strings (not address them), there is a super 'extra' in the CCS code, to help with this. If you write a routine like this:
void send_byte(int8 ch) {
do_something_with_a_character_here(ch);
Then this routine can be called with a constant string as:
send_byte("A constant string");
or
send_byte(name_of_a_constant_string);
and the code will automatically call the single character routine for each character in the constant string. This is how you can use 'putc("A constant string");
This produces fast/tight code, and provided you only want to deal with such strings 'sequentially', not to do random access, works fine.
