A/D conversion for temperature sensor LM35
maria
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sun Jul 31, 2005 10:57 am     Reply with quote
I'm trying to do A/D conversion for the Temperature sensor LM35 and my code doesnt work, can any of you guys tell me what's wrong with my code.. Code:
the error that gives me is this:
Error 23 "C:testadtemp.c" Line 6(8,9): Can not change device type this far into the code
*** Error 48 "C:testadtemp.c" Line 6(9,12): Expecting a (
*** Error 43 "C:testadtemp.c" Line 6(13,14): Expecting a declaration
is in the line where i declared
#device ADC=8
#include <16F877.h>
#include <STDLIB.H>
#device ADC=8 //set for 8 bit A/D
int Tempvalue=0;
int Temp;
//Define the A/D control register
#BYTE ADCON0=0X01
//Check Temperature Function
void check_Temp() {
set_adc_channel(0);
while(input(PIN_A0))
Tempvalue=read_adc();
if(Tempvalue>=0) //64 to test put 0
{ Temp=1;
output_high(PIN_B0);
{ Temp=0;
output_low(PIN_B0);
HELP !!!
LomasS
PostPosted: Sun Jul 31, 2005 12:58 pm     Reply with quote
It looks like a conflict between the #device and something in STDLIB.H.
Place the #device ADC=8 between the other #includes:
#include <16F877.h>
#device ADC=8
#include <STDLIB.H>
That compiled OK for me.
Note that your code is incomplete as there is no main() function.
Steve.
Mark
PostPosted: Sun Jul 31, 2005 5:04 pm     Reply with quote
Make sure that you only have 1 C file if using MPLAB. A common mistake is to use multiple source files in the project workspace. You cannot do this. You must include any C files in your main C file by using the #include
languer
Why location of #device ADC=8 is important
PostPosted: Sun Jul 31, 2005 11:34 pm     Reply with quote
Look here to understand why the location of the following command is important.
#device ADC=8
