mattmab
int32 |
Posted: Sat Mar 13, 2004 11:55 pm |
does anyone understand why this wont work? it seems i cant initialze leds to hex 4000.
thanks ahead - matt
#case
#include <16f876.h>
#device *=16 ICD=TRUE
#use delay( clock=11059000 )
int32 leds = 1;
leds = 0x4000;
Re: int32 |
Posted: Sun Mar 14, 2004 3:42 am |
mattmab wrote: | does anyone understand why this wont work? it seems i cant initialze leds to hex 4000.
thanks ahead - matt
#case
#include <16f876.h>
int32 leds = 1;
leds = 0x4000;
Should work. Try declaring the constant as a long - so:
leds= 0x4000L;
Sometimes the compiler is less than 'intelligent' about such things...
mattmab
int32a |
Posted: Sun Mar 14, 2004 9:59 pm |
nope,4000L dont work either, it takes it as a 16 bit. it works if i use make32(), but that seems like a poor way. does 32 bit math work? i never checked...
thankws - matt |
Posted: Sun Mar 14, 2004 10:51 pm |
It actually does work. If I take your code here,
Code: | #case
#include <16f876.h>
int32 leds = 1;
leds = 0x4000;
and compile it with PCM vs. 3.184, I get this result in the .LST file:
Code: | 0011 01A3 00277 CLRF 23
0012 01A2 00278 CLRF 22
0013 3040 00279 MOVLW 40
0014 00A1 00280 MOVWF 21
0015 01A0 00281 CLRF 20 |
The symbol table shows that 'leds' is at address 0x20:
The ASM code is setting the memory locations as follows:
0x23 = 0
0x22 = 0
0x21 = 0x40
0x20 = 0
Since CCS stores variables in Intel Lo-Hi format, this means
that 'leds' = 00 00 40 00 which is correct.
I suspect that the problem is in how you are viewing the 'leds' variable.
For example, if you're using printf, you need to specify the format
string as "%lx", and not "%x", in order to display a 16 or 32-bit number. |
