set_timer2() Inquiry
chingB
PostPosted: Wed Mar 10, 2004 6:13 am     Reply with quote
Any one of the community who can provide me with a mathematical calculation for set_timer2().
Say: I have setup_timer_2(T2_DIV_BY_16,100,10)
and I want to set_timer2() to a certain count value ?
Need help on this.
Thank u.
asjad
PostPosted: Wed Mar 10, 2004 3:47 pm     Reply with quote
The calculation is as follows
(1/external crystal) *4*timer prescaler =X
suppose you insert value of 20 in tmr0 register
255-20 = 235
Now total timer 0 time = X(from above calculation) * 235
If you vary the value in tmr0 register you can alter the time between
interrupts
Best Regards
Neutone
Re: set_timer2() Inquiry
PostPosted: Wed Mar 10, 2004 5:48 pm     Reply with quote
chingB wrote:
Need help on this.
Thank u.
In your example
T2_DIV_BY_16 = 16 instruction cycles to increment the timer
100 = 101 timer increments to overflow
10 = 10 overflows to set the interupt flag
