I thought I'd move up to MPLAB 6.4 from 5.x and I'm having some issues. I installed the plugin and now I can compile from MPLAB 6.4 but there doesn't seem to be any connection between the Debugger and the out .HEX file. In 5.X I would hit BUILD-ALL and after the build the hex would be loaded into program memory in the debugger and I could run the emulator (ICE 2000) from my C code. In 6.4 it compiles but I have to manually go and import the .HEX file and there doesn't seem to be any debugging information as I can only work in ASM, there is no tie to the C source files.
Am I missing something here?
asjad
Joined: 09 Mar 2004 Posts: 52 Location: Greater Manchester - UK
Posted: Tue Mar 09, 2004 12:12 pm
If you look in the folder where you created your source file you will
see a file with the extension LST
eg..
clock.LST
If you open this LST file you will get a combination of
C code and the asm equivalent to each line in your source code.
If you do not like the combination of C & ASM, then in MPLAB
goto project>build options>project. then goto the CCS tab
here you can change the way the LST file is generated (i.e pure asm)
