PORTB Pull-ups
Haplo
PORTB Pull-ups
PostPosted: Sun Mar 07, 2004 5:53 am     Reply with quote
Hi
Is the weak pull-up on PORTB of PIC16F877 strong enough to drive the ouputs of a LM339 comparator? Thanks.
Neutone
Re: PORTB Pull-ups
PostPosted: Sun Mar 07, 2004 11:17 am     Reply with quote
Haplo wrote:
Hi
If you only have the comparator wired to the portB pin it should be fine at low frequency.
Haplo
PostPosted: Sun Mar 07, 2004 4:19 pm     Reply with quote
Thanks for your answer. I assume 1KHz-10KHz is low frequency, right?
