delay_ms(time)? variable? constant?
MikeV
PostPosted: Fri Mar 05, 2004 12:53 pm     Reply with quote
What does it mean that we can do delay_ms() for a variable 0-255 or a constant 0-65535?
I assume we can only have an int in the argument there, right? Otherwise, a hard-coded number will be interpreted by the compiler as valid anywhere from 0-65535?
So the following is invalid?
long x;
delay_ms(x);
I compiled it and there is no warning or error. So CCS then just truncates the variable?
PostPosted: Fri Mar 05, 2004 5:40 pm     Reply with quote
long x;
delay_ms(x);
Based on looking at the .LST file output, apparently so.
Here is one of my old posts with a routine that accepts
a 16-bit parameter.
http://www.ccsinfo.com/forum/viewtopic.php?t=375
