What does it mean that we can do delay_ms() for a variable 0-255 or a constant 0-65535?
I assume we can only have an int in the argument there, right? Otherwise, a hard-coded number will be interpreted by the compiler as valid anywhere from 0-65535?
So the following is invalid?
long x;
delay_ms(x);
I compiled it and there is no warning or error. So CCS then just truncates the variable?
Posted: Fri Mar 05, 2004 5:40 pm
long x;
delay_ms(x);
Based on looking at the .LST file output, apparently so.
