2 sensors handling
edi
2 sensors handling
PostPosted: Thu Mar 04, 2004 4:44 am     Reply with quote
I have 2 digital sensors connected to 2 I/O's pins, one to PORTA.2 and one to PORTA.3.
I have a good function that handle the reading of the sensors.
My question is: how can I use the same reading function, for both sensors.
I want to call the function once to handle PORTA.2, and once to handle PORTA.3.
Thanks,
Edi
Neutone
PostPosted: Thu Mar 04, 2004 8:26 am     Reply with quote
I would read both sensors at the same time if they were on diferent pins and of the same type. It will cost half as much time.
edi
PostPosted: Thu Mar 04, 2004 8:53 am     Reply with quote
I can't do that because they are not working at the same time.
Neutone
PostPosted: Thu Mar 04, 2004 9:10 am     Reply with quote
Post your good function.
edi
PostPosted: Thu Mar 04, 2004 3:52 pm     Reply with quote
Neutone, you can see the function that works now for Sensor1.
I need to run it also for Sensor2, currently I copy the function and change Sensor1 -> Sensor2, but isn't an elegant way to run the same function one time for Sensor1 (just point the function to the specific I/O bit - portA.2)
and second time for Sensor2 (point the function to I/O bit - portA.3)
Thanks in advance,
Edi
#include <16f877a.h>
//#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,PUT
#use fast_io(A)
#use fast_io(B)
#byte porta=5
#byte trisa=0x85
#byte portb=6
#byte trisb=0x86
#bit Sensor1 = porta.2
#bit Sensor2 = porta.3
int8 read_code_sensor1()
   int8 err=0;
   int8 index;
   int16 timeout;
   for (index=0; index<5; index++)     // clear the last read code
      press[index]=0;
      delay_ms(10);
      if (Sensor1==0)
         delay_ms(10);         // debounce
         if (Sensor1==0)
            LED = 0;           // turn on led
            do
               press[index]++;
               delay_us(30);
               if (press[index]>ProgTime)
                  LED = 1;
                  return 2;
            while (Sensor1==0);
            LED = 1;
            delay_ms(10);
      timeout=0;
      do
         timeout++;
         delay_us(50);
         if (timeout>ProgTime)
            return 2;
      while ((Sensor1==1) && (index<4));
   for(index=0; index<5; index++)
      if (press[index]==0)
         return 2;
   return 1;
Neutone
PostPosted: Thu Mar 04, 2004 4:20 pm     Reply with quote
Do you need a seperate press array for both sensors or can you use the same for both? I am assuming you have continous pulses on each sensor input and thats why you cant read both at the same time? I would pass a Flag to the function to select the sensor to be read.
In each place you find
Sensor1==0
replace with
(!Sensor1&&Flag)||(!Sensor2&&!Flag)
Sensor1==1
replace with
(Sensor1&&Flag)||(Sensor2&&!Flag)
edi
PostPosted: Sat Mar 06, 2004 3:36 pm     Reply with quote
Good idea,
Thanks a lot.
