bennyboos
Can I reallocate which area of RAM is used by the compiler |
Posted: Thu Apr 20, 2006 3:30 am |
Is it possible to force the compiler to use different areas of RAM if for it's internal affairs? For example supposing I wanted to use the first 32 bytes from 0x00 to 0x1F for my own use and let the compiler use the remaining ramspace?
The following program doesn't do anything special but is useful for illustrating my qeury.
Code: | #device PIC18F4331
#define VARIABLE_ADDR 0x002
#reserve VARIABLE_ADDR, VARIABLE_ADDR
int variable;
#locate variable=VARIABLE_ADDR
#org 0x0200,0x02FF
while(1) variable++;
As it stands this compiles OK, however if I change VARIABLE_ADDR to 0x001 or 0x000 I get the following compilation error:
Error 103 : Constant out of the valid range 001 is reserved by the compiler
I appreciate that the compiler may need to use additional RAM at some point, however when I examine the dissasembly file I cannot see anywhere where RAM locations 0x000 or 0x001 are being used?
Code: | 1: #device PIC18F4331
0000 EF00 GOTO 0x200
2: #define VARIABLE_ADDR 0x002
3: #reserve VARIABLE_ADDR, VARIABLE_ADDR
4: int variable;
5: #locate variable=VARIABLE_ADDR
6: #org 0x0200,0x02FF
7: void main(void)
8: {
0200 6AF8 CLRF 0xff8, ACCESS // Clear TBLPTRU
0202 9ED0 BCF 0xfd0, 0x7, ACCESS // Disable interrupt priority
0204 6AEA CLRF 0xfea, ACCESS // Clear FSR0H
0206 6AE9 CLRF 0xfe9, ACCESS // Clear FSR0L
0208 90B9 BCF 0xfb9, 0, ACCESS // Clear bit 0 of ANSEL1,
020A 9CC1 BCF 0xfc1, 0x6, ACCESS // Clear bit 6 of ADCON1,
020C 9EC1 BCF 0xfc1, 0x7, ACCESS // Clear bit 7 of ADCON1,
020E 0E00 MOVLW 0 // Write literal of 0 into W
0210 6EB8 MOVWF 0xfb8, ACCESS // Copy W into ANSEL0
9: while(1) variable++;
0212 2A02 INCF 0x2, F, ACCESS // Increment RAM at 0x02
0214 D7FE BRA 0x212 // Loop back one
0216 0003 SLEEP |
Thanks,
Ben |
Posted: Thu Apr 20, 2006 7:07 am |
Use somewhere else!...
Three comments. 'Reserve', is designed to _stop_ the compiler using the area, then you tell it to put a variable into this area. If you want other code to use an area, reserve it. If you want to force a variable to a particular location, locate it. Don't do both to the same area.
Second comment, the syntax for reserve, is start address:end address.
Third comment. The reason for the problem, is that the first area of memory, is the 'access bank', useable in all pages of memory. The compiler doesn't make much use of this ability, but uses the first four bytes, for it's scratch area....
