homfray
18F452, FRAM & SSPADD, How do I set SCL = 1Mhz clock |
Posted: Fri Mar 05, 2004 9:23 am |
18F452
40Mhz Clock
PCH
FRAM FM24C256
I have some code which uses code that I found on this forum. The SCL runs whatever I do at 100KHz when I want to run it at a 1MHz, my suspicion is that I am not able to alter the special 12c registers. I know somewhere I have to set SSPCON, SSPADD and SSPSTAT
and what I have been doing is setting it up as follows
#include <18F452.h>
#device *=16 ADC=8
// DEFINES
#define EEPROM_PAGE_LEN 64 // Page length in bytes
#define EEPROM_PAGE_COUNT 512 // Nunber of pages in eeprom
#define EEPROM_I2C_WRITE_ADDR 0xA0
#define EEPROM_I2C_READ_ADDR 0xA1
// COMPILER DIRECTIVES and HARDWARE CONFIGURATION
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use Delay(Clock=40000000)
#use i2c(Master, SDA=PIN_C4, SCL=PIN_C3, FORCE_HW) // Hardware i2c
#zero_ram
// GLOBALS
char random_byte;
int value;
char page_write_buffer[EEPROM_PAGE_LEN];
char page_read_buffer[EEPROM_PAGE_LEN];
#byte SSPCON = 0x28 // setting bit 5 and 3 high = SSPEN and SSPM3
#byte SSPADD = 0x0A // with a 40MHz clock this should be right
#byte SSPSTAT = 0x80 //setting bit 7 high = SMP
this gives me a 100KHZ clock when I want a 1MHz clock. I have changed SSPADD to 0x9 and I get the same I also have changed SSPCON to SSPCON1 and this does nothing either???
Do I need to add
Code: | #define SSPSTAT 0xFC7
#define SSPCON1 0xFC6
#define SSPADD 0xFC8
here
#include <18F452.h>
#device *=16 ADC=8
// DEFINES
#define SSPSTAT 0xFC7 //
#define SSPCON 0xFC6 // PUT IT HERE!!!!!
#define SSPADD 0xFC8 //
#zero_ram
// GLOBALS
char random_byte;
int value;
#byte SSPCON = 0x28
#byte SSPADD = 0x0A
When I try this all i get is build fail error
Expecting an identifier
Expecting a declaration
I am using 2K2 pull up resistors on SDA and SCL
HELP ME WISE PEOPLE
I HAVE CHANGED ALL RANDOM VARIABLES AND AM SITTING HERE LOOKING STUPID!!!! |
Posted: Fri Mar 05, 2004 11:18 am |
#define SSPADD 0xFC8 |
You are porting code that talks directly to registers, from a 16F877
to a 18F452. To do this, you need to change the addresses of
those registers to the appropriate addresses for the 18F452.
In CCS, a register address (or memory location) is declared with
a #byte statement. The original code used #byte statements.
You should do this in your ported code, as well.
So change your code to this:
#byte SSPSTAT = 0xFC7
#byte SSPCON1 = 0xFC6
#byte SSPADD = 0xFC8
You also need to check the data sheet for the 18F452, and see
if there are any differences in the register bits or usage, between
the 16F877 and the 18F452. |
