How to initialize a static structure in a function?
janet
PostPosted: Thu Mar 04, 2004 6:41 pm     Reply with quote
if i want to initialize a static variable in a function, i could write
void test() {
static int8 number = 0x88;
printf("number: %2X", number++);
But if i want to initialize a static structure in a function, what should i do?
typedef struct _NUM {
BYTE a;
BYTE b;
} NUM;
wedilo
PostPosted: Fri Mar 05, 2004 1:47 am     Reply with quote
Hello janet,
please try this without 'typedef' if possible
void test()
   static struct
      BYTE a;
      BYTE b;
   } NUM;
Hope that helps you
73 Sven
