I am using the ICD-U40 to program a PIC18F6520. When I program my board the "Verification Results" window pops up and there is a lot of stuff in RED. What does the "Raw Data" refer to?
Hello Gast,
Sometimes, normally at first start of the CCS IDE and compiling the code I have the same problem. But after another compile it will working fine.
I use a 18F452, but that can't the reason.
It seems so the there is nobody in the forum who know a solution.
I think you should inform CCS under SUPPORT@CCSINFO.COM
Tell them all information compiler version etc.
