ICD - U40 Configuration fuses
PostPosted: Mon Mar 01, 2004 2:39 pm     Reply with quote
I am using the ICD-U40 to program a PIC18F6520. When I program my board the "Verification Results" window pops up and there is a lot of stuff in RED. What does the "Raw Data" refer to?
I get
Actual: 00 21 0C 0E 83 01 81 00 0F C0 0F E0 0F 40
Expected: 00 21 0C 0E 83 01 81 00 FF C0 FF E0 FF 40
I have no idea what this means or how to modify it.
I also have a whole bunch of fuses that don't match. I tried changing them in the firmware, but it didn't change anything.
Can someone help me out?
Thanks,
mle
wedilo
PostPosted: Tue Mar 02, 2004 1:54 am     Reply with quote
Hello Gast,
Sometimes, normally at first start of the CCS IDE and compiling the code I have the same problem. But after another compile it will working fine.
I use a 18F452, but that can't the reason.
It seems so the there is nobody in the forum who know a solution.
I think you should inform CCS under SUPPORT@CCSINFO.COM
Tell them all information compiler version etc.
73 Sven
