Pedro
write_eeprom donīt work. |
Posted: Wed Feb 25, 2004 9:36 pm |
Hello , i try this but donīt work :
I use PCWH v.3.184.
My fuses are : HS,WDT128,MCU,PROTECT,NOCPD,NOWRTD,NOPUT,NODEBUG,NOVLP,NOOSCSEN,NOBROWNOUT,NOWRTC
#Rom 0xf00000={0x00,0x00}
int teste;
write_eeprom(0,0x10);
teste=read_eeprom(0);
the teste value is 0x00 and not 0x10.
Any idea ????? please....
[]s Pedro |
Posted: Wed Feb 25, 2004 10:01 pm |
The picmicro is 18f8720. |
Posted: Thu Feb 26, 2004 3:11 am |
Anonymous wrote: | The picmicro is 18f8720. |
I think you have your fuses confused...
'NOCPD', means that the code area is not protected. 'PROTECT', means that the data EEPROM _is_...
Tony Helinski
Posted: Thu Feb 26, 2004 1:17 pm |
I believe you need to do this:
#rom int8 0xF00000 =
If you don't use the int8 the compiler uses int16 |
Posted: Thu Feb 26, 2004 2:52 pm |
Hello tankīs , but the problem is with write_eeprom , i use #rom int8.
Tankīs for any help. |
