javabear
i2c 24c256 ex_extee.c setup_spi(FALSE) |
Posted: Sun Feb 22, 2004 11:13 pm |
[frank@picard frank]$ ccsc +v
PCM compiler version 3.168 (linux, RH9)
I was running some test code from PCM programmer 24lc256.c
on a pic16f876 and 24c256 eeprom via i2c.
All is well, thanks for the example code.
Now the strange part (or maybe I am tired).
if i run ex_extee.c, reads and writes do not work
reads return 0xff and writes hang.
however if I add 1 extra line after init_ext_eeprom
init_ext_eeprom(); <-- existing line, no change
setup_spi(FALSE); // added by me - program now works ... aaarrgh !!!!!!
then it all works.
I have read some discussions about using setup_spi(FALSE); so
now I am confused.
Has anyone else seen this ??
Thanks |
Posted: Mon Feb 23, 2004 12:34 am |
Quote: | if i run ex_extee.c, reads and writes do not work
reads return 0xff and writes hang. |
I'm not familiar with the Linux version, but here are my thoughts:
I assume that you have edited the EX_EXTEE.C file, to #include
the CCS driver file, 24256.C.
I assume that you are using pins C4 and C3 for SDA and SCL.
So, in the EX_EXTEE.C file, place the following lines above the
line for #include <24256.c>
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
Example:
Code: | #define EEPROM_SDA PIN_C4
#include <24256.c> |
See if that makes a difference. |
Posted: Mon Feb 23, 2004 9:22 pm |
PCM programmer wrote: | Quote: | if i run ex_extee.c, reads and writes do not work
Example:
Yep, I had previously tried as you have mentioned. I know the pins are ok as
the code works once I add setup_spi(FALSE); Hmm thanks anyway.
The only thing I can think of is that perhaps the latest Linux CCSC release is
3.168 while the latest windows version is 3.185 and maybe there are some
bug fixes I am missing. I have enquired about the difference to CCS but no
answer thus far.
Cheers / Frank ![Very Happy](images/smiles/icon_biggrin.gif) |
