Is it just me or does anyone else have problems with the example programs that come with the compiler?
I'm using a 16F877 instead of the 16c74 and I've change the header reference to reflect that.
For example, EX_RTC.C runs and asks me to set the clock. After setting the clock and asking the pic to display the clock, it doesn't return good info.
Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Posted: Mon Feb 09, 2004 8:42 pm
What realtime clock did you connect to it... none of the PIC processors have a build in realtime clock ( at least none that I am aware of)
johngalt47
Posted: Wed Feb 11, 2004 12:16 pm
It is the real time clock that came in the kit I bought from CCS. I tried finding some info on the web regarding this rtc but the number written on the chip apparently doesn't exist on the net.
languer
RTC Part Info
Posted: Wed Feb 11, 2004 1:36 pm
This is not an answer to your original question, but I beleive this is the information pertaining to the RTC IC that comes with some kits.
