Functions &interrupts
asjad
PostPosted: Tue Mar 09, 2004 11:57 am     Reply with quote
I am a new comer to the CCS compiler
(A) What is the best version of MPLAB to use with PCM compiler
(Most compatible)??
(B) Is it possible to call functions within a ISR() routine
(C) When you include a ISR - eg #int_rtcc, should self made functions
be placed above or below the RTCC ISR??
Best Regards
Neutone
Re: Functions &interrupts
PostPosted: Tue Mar 09, 2004 12:06 pm     Reply with quote
(Most compatible)??
I have quit using MPLAB completely. I use the ICD-U to program from within the CCS IDE. There are several ways to use the compiler though.
You can call a function from within an interupt. It's best not to use the same functions from both within an interupt and main.
The function or at least a prototype must be defined prior to the code that calls the function.
PostPosted: Tue Mar 09, 2004 12:20 pm     Reply with quote
(Most compatible)?
Vs. 5.70.40 works well with PCM. But you don't get the C syntax
coloring in that version.
http://www.microchip.com/1010/pline/tools/archive/mplabi/
I've used vs. 6.40 and 6.42 with PCH and the ICD2 debugger.
Of those two, I would say 6.42 works the best. But now they're
up to vs. 6.43. It's free. Just try it. (It will work with PCM, too).
http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/mplab6/index.htm#mplab1
