PROBLEM WITH DEBUGGER MODE ICD2-18F6520
Roberto da Rivoli
PostPosted: Wed Feb 11, 2004 5:47 am     Reply with quote
ICD0083: Target not in debug mode, unable to perform operation
ICD0069: Unable to run target
18F6520
I HAVE THIS PROBLEM WHIT ICD2
THE CONFIGURATION BIT IT'S OK
THE ELECTRIC CONNECTION IT'S OK
Sad Sad
PostPosted: Wed Feb 11, 2004 11:54 am     Reply with quote
The major reason for this, is that you have not compiled your code
for use with the ICD2 debugger. Do this to fix it:
Go to this menu: Project / Build Options
Then enable the box for: Compile for use with ICD Debugger
MPLAB vs. 6.40 does not retain this setting. You have to set it
everytime you start MPLAB.
