i am using a 16f628 with INTRC_IO for the clock. Timer0 generate an intteruption every 200 µs. when i make a simulation on Mplab all is good, but when i transfert the soft in the 16f628 nothing appens. Somebody can help me?. Thank you
Posted: Sun Feb 08, 2004 3:51 pm
Make sure that the Config Bits are setup correctly, when you
program the PIC in MPLAB. CCS calls these bits "fuses".
What programmer are you using ? PicStart-Plus ? or ICD2 ?
