Duane B Guest
ICD-U40 not working |
Posted: Thu Jul 10, 2003 11:32 pm |
Hello everyone,
When trying to use the ICD-U40 (driver updated 7/10) with PCWH 3.168 I get this error.
"Cannot open the USB port. Invalid handle."
Any clues as to what could be causing this?
Thanks,
Duane
___________________________
Original Post ID: 144515863 |
snoopy Guest
Posted: Mon Dec 08, 2003 7:17 pm |
Are you working on W2K, win98, winxp ? |
wedilo
Joined: 16 Sep 2003 Posts: 71 Location: Moers, Germany
Posted: Tue Dec 09, 2003 4:44 am |
Hello Duane B,
Did you have still running the 'ftd2xxun.exe' ?
I think that's for the announcement of the 'ftd2xx' drivers to the whole system.
73 Sven |
TL
New driver |
Posted: Wed Dec 10, 2003 2:59 am |
There is a new ICD-U driver (09 Dec) software on the CCS download page. |
agrj
Posted: Mon Feb 02, 2004 6:28 am |
I can't find the driver for ICD-U dated 9/dec. the only one I found is 29/aug.
where is it?
thanks |
TL
Posted: Tue Feb 03, 2004 10:51 am |
There are bugs in 9 Dec and 22 Dec ICD updates. Also, 13 Jan update allows the compiler to compile and flash download but my target application didn't run. I have now gone back to the 28 Oct update.
You should download 13 Jan (the latest version) from CCS site and try it. If it doesn't work, I can send you the 28 Oct update if you give me your email address.
I have ICD-S and I assume the updates work for ICD-U. |
agrj
Posted: Tue Feb 03, 2004 1:01 pm |
TL wrote: | There are bugs in 9 Dec and 22 Dec ICD updates. Also, 13 Jan update allows the compiler to compile and flash download but my target application didn't run. I have now gone back to the 28 Oct update.
if you could send me your version I would be glad. my e-mail is: agrj@aes.com.br
Thanks |
TL
Posted: Wed Feb 04, 2004 10:01 am |
Hi Agry,
I have tried sending you the update on 2 occasions but I got an error message saying I couldn't deliver it to you. Are you sure your email address is correct? Also, is your email account buffer nearly full? The update is about 1.1MB in size - can your account accept this size? |
agrj
Posted: Wed Feb 04, 2004 10:34 am |
TL,
yes I'm able to receive large e-mails and my mailbox is empty now. if you would like to try again, go ahead.
just to check my e-mail is agrj@aes.com.br
thanks |
TL
Posted: Wed Feb 04, 2004 10:48 am |
Hi Agry,
Sorry, I have sent it again and got an error message again. Could you ask others or CCS to help you. |
agrj
Posted: Wed Feb 04, 2004 11:07 am |
I think I found the problem. the correct is AGRJ and not AGRY . which one are you using?
thanks
Arlydo |
TL
Posted: Wed Feb 04, 2004 11:14 am |
Hi Agrj,
Yes, I used agrj@aes.com.br. I clicked on your email address. |
