Convert integer to string
Jack_B
PostPosted: Thu Oct 14, 2004 12:14 pm     Reply with quote
Hi all,
With the PIC18F1320 I communicate with a Diplay(EA Dip204-4) over the serial SPI Interface. The data which I send are in an integer variable (for example: 50). The Problem is I can only send an string variable (for example: char value[]="50") to the display.
My Question: It`s possible to convert an integer to a string?
thanks for the help
Sorry for my bad English ;)
dave
PostPosted: Thu Oct 14, 2004 12:33 pm     Reply with quote
Use the sprintf() function as described in the CCSC manual, as is pasted below. Very Happy
SPRINTF()
Syntax:
 sprintf(string, cstring, values...);
Parameters:
 string is an array of characters.
cstring is a constant string or an array of characters null terminated.  Values are a list of variables separated by commas.
Returns:
 Nothing
Function:
 This function operates like printf except that the output is placed into the specified string.  The output string will be terminated with a null.  No checking is done to ensure the string is large enough for the data.  See printf() for details on formatting.
Availability:
 All devices.
Requires
 Nothing
Examples:
 char mystring[20];
long mylong;
mylong=1234;
sprintf(mystring,"<%lu>",mylong);
// mystring now has:
//      < 1 2 3 4 > \0
Example Files:
 None
regards Dave
Jack_B
PostPosted: Thu Oct 14, 2004 1:15 pm     Reply with quote
thanks for the detailed answer Very Happy
