lanyong
Joined: 14 Jan 2004 Posts: 9 Location: Xiamen,Fujian Province, China
another bug??? (test.c) |
Posted: Thu Jan 15, 2004 7:15 pm |
#if defined(__PCB__)
#include <16c54.h>
#fuses HS,WDT,NOPROTECT
#use fast_io (A)
#use fast_io (B)
#elif defined(__PCM__)
#include <16F84.h>
#use fast_io (A)
#use fast_io (B)
SET_TRIS_B( 0x04 );
SET_TRIS_A( 0x01 );
setup_wdt(WDT_2304MS);
restart_wdt();
sleep();
output_high(pin_a1); //12bit can't get here,but 14bit can!
output_high(pin_b0);
//i think there r a bug in 12bit wdt or sleep!
//pls help me, thinks:) |
lanyong
sorry , it is my mistake. |
Posted: Thu Jan 15, 2004 9:12 pm |
12 bit sleep wake up is diff. from 14bit, so sorry!
#include <16c54.h>
#use fast_io (A)
#use fast_io (B)
SET_TRIS_B( 0x04 );
SET_TRIS_A( 0x01 );
restart_wdt();
output_low(pin_a1);
output_low(pin_b0);
sleep();
//¹þ¹þ£¬²»»áËÀ£¡it will run for ever:) |
