kbhit() and stream inquiry
chingB
PostPosted: Thu Jan 15, 2004 2:54 am     Reply with quote
Hi
I plan to use a hardware interrupt uart for receiving data from a computer. I search this community for a code snippet in using #int_rda and I gain few tips in using interrupt service routine.
My concern is: would it be possible to use kbhit(Com1) and circular buffer method for receiving incoming packets from the computer.
#define RX_SIZE 64
byte rxbuffer[RX_SIZE];
byte rx_in  = 0;
byte rx_out = 0;
#int-rda
void serial_rx()
     int t;
     if (kbhit(COM1))
           t = fgetc(COM1);
           rxbuffer[rx_in] = t;
           rxchksm ^= t;
           rx_in = (rx_in+1) % RX_SIZE;
Need you comments on this....
Thank u.
Humberto
PostPosted: Thu Jan 15, 2004 5:39 am     Reply with quote
Yes of course. There aren't any connection between them.
kbhit() returns TRUE if the start bit of a character is being received on the RS232 RCV pin.
circular buffer is a way to store incoming bytes in memory.
regards,
Humberto
Humberto
PostPosted: Thu Jan 15, 2004 6:02 am     Reply with quote
regards,
Humberto
