Internal Error On Compilation
arga
PostPosted: Mon Jan 12, 2004 4:14 pm     Reply with quote
When I sometimes compile my program the following message comes up:
Internal Error - Contact CCS DEBUG FILE
The thing is, even wihout changing the code and recompiling it again, it compiles successfully. The error message doesn't happen all the time.
The error message started to appear since using a do-while statement.
I'm using CCS Ver. 3.173
Why is this so?
franckcl
PostPosted: Tue Jan 13, 2004 10:29 am     Reply with quote
I've already had this problem too.
I think this append sometime when the compiler can not write to an output file when this file is already open by another software or if this file have read only attribute set.
Search maybe in that way.
Franck
