switch statement
chava
switch statement
PostPosted: Tue Jan 13, 2004 2:38 pm     Reply with quote
Hi
sily but..
I wrote:
do temp++; while (bit_test(PIN_E1));
and got the error message:
Error[102] E:\chava\kav-kor\kav-kor2.c 35 : Expect comma
does someone knows what wrong(I know its dummy)[/quote]
chava
sorry... do statement
PostPosted: Tue Jan 13, 2004 2:39 pm     Reply with quote
Embarassed
chava
found it !
PostPosted: Tue Jan 13, 2004 2:47 pm     Reply with quote
SORRY.
PostPosted: Tue Jan 13, 2004 2:49 pm     Reply with quote
If you get an error you don't understand, you should look
up the syntax of the C statement on the net.
For example, here it is for the do-while statement:
http://www.cee.hw.ac.uk/~pjbk/pathways/cpp1/node129.html
If everything looks OK there, you should look up the
syntax for the CCS function that you are using.
http://www.ccsinfo.com/ccscmanual.zip
Then you may discover not only a syntax
error, but that you're not using the best function.
Then check the manual to find a better one.
