chingB
Using two(2) #use rs232 with stream? |
Posted: Sun Jan 11, 2004 6:11 pm |
I am aware that you can use two(2) #use rs232 directive together with stream.
How can I use the printf function such that I can specify which rs232 to use? like if u are sending to lcd display u have syntax stated below:
printf(lcd_putc,"This is a sample text %lu",numb);
Anyone have done this method of printf function which you can be able to direct to a specific rs232 if two wer define in the program?
I need info, help or a code snippet will do....
Thank you. |
Haplo
Posted: Sun Jan 11, 2004 8:05 pm |
I'm quoting this from the manual:
Quote: |
Syntax:
printf (fname, cstring, values...)
fprintf (stream, cstring, values...)
If fprintf() is used then the specified stream is used where printf() defaults to STDOUT (the last USE RS232).
You have to use fprintf if you want to specify streams. |
