I've a question. maybe very simple.
It's about rs232,
I want to get a lot of receive data to PIC16F876 from another PIC16F876 (and PC).
I save an array that my receive data. But I suppose gets() function is receive as string. But I want to integer (hex). Because if this receive string I see ascII character on the ports.
thanks a lot
Posted: Wed Mar 18, 2009 11:49 am
You can use putc() to send any byte value. It does not require ASCII
values.
