Minimum for CCS' TCP/IP stack to work with TCP comms
javick82
PostPosted: Fri Jul 27, 2007 9:00 am     Reply with quote
What are all the files needed for the TCP/IP stack to work if I only want to use TCP communication?
I am using the PICDEM.net 2 board with the 18F97J60 microcontroller and ENC28J60 ethernet chip. Required reconfiguration of the hardware.h file to get it to run, I just want to make sure I am not including unnecessary code.
Thanks!
