timer 0 help
seanyGood
View user's profile Send private message Send e-mail AIM Address
timer 0 help
PostPosted: Wed Jan 07, 2004 6:34 pm     Reply with quote
Hi everybody,
I am new to using timers on the PIC, and i am having a little trouble. I am using a PIC 16F877 (on the MP-LAB ICD demo board) and an 8 Mhz clock. I want the timer 0 interrupt to occur every 10 ms. So here are my calculations: 8000000/(4*128) == 15625 increments per second. So (15625 increments)/(1 second) == (X increments)/(10*10^-3 seconds).
Solve for X, and that gives me 156.25 increments/10ms. So in order to get 156 increments before overflow, i use the statement
set_rtcc(100);
Anyways, i set up a little test program to see if i was correct, and apparently i am missing something. I set up a counter in the timer0 interrupt, and so when the counter reaches 500, that should be 5 seconds, when it reaches 1500 that should be 15 seconds and so on. In the 5 second case, the actual time it is taking is 8.5 seconds. In the 15 second case the actual time it is taking is 25 seconds. So I will post my code below in case the problem can't be found in my above calculations. Thanks for any help you can give!
* includes
#include <16F877.h>         /* device file for demo board use */
* directives
//DEBUG remove unnecessary fuses after testing
#fuses XT,         \
       NOWDT,      \
       NOPROTECT, \
       NOLVP,      \
       DEBUG
#use delay (clock=8000000)          //DEBUG Use with Microchip ICD demo board
* enumerations
enum ADU_STATES
   STATE_LED_OUTPUT,
   STATE_ADU_STATE_MAX
* prototypes
void initialize();
void timeInit();
void LED_Output();
#int_rtcc
void ISRmbTimer();
* constants
/*LED output pins */
#define CRITICAL_LED_PIN      PIN_C2 /* 17 */
#define MAJOR_LED_PIN         PIN_C1 /* 16 */
#define MINOR_LED_PIN         PIN_C0 /* 15 */
/* Times in 10 ms increments */
#define TIME_ONE                500     // 5 seconds
#define TIME_TWO                1500    // 15 seconds
#define TIME_THREE             4500    // 45 seconds
* globals
ADU_STATES progState;
int32 timeCounter;
#int_rtcc
void ISRmbTimer()
   timeCounter++;
void timeInit()
   int8 i;
   timeCounter = 0;
   /* set real-time clock counter to interrupt every 10ms */
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
   set_rtcc(100);
   enable_interrupts(int_timer0);
   progState = STATE_LED_OUTPUT;
void LED_Output()
   if (timeCounter > TIME_THREE)
      output_High(CRITICAL_LED_PIN);
      output_Low(CRITICAL_LED_PIN);
   if (timeCounter > TIME_TWO)
      output_High(MAJOR_LED_PIN);
      output_Low(MAJOR_LED_PIN);
   if (timeCounter > TIME_ONE)
      output_High(MINOR_LED_PIN);
      output_Low(MINOR_LED_PIN);
   timeInit();
   while (true)
      switch(progState)
         case STATE_LED_OUTPUT:
            LED_Output();
            default:
PostPosted: Wed Jan 07, 2004 7:15 pm     Reply with quote
The RTCC does not automatically reload itself with the preset value.
You have to do it the isr. See the CCS examples, EX_SINE.C and
EX_DTMF.C.
seanyGood
timer 0 help
PostPosted: Wed Jan 07, 2004 7:47 pm     Reply with quote
Right on the money PCM Programmer. Thanks.
