24LC256 eeprom
Robert Moore
24LC256 eeprom
PostPosted: Mon Jan 05, 2004 12:48 am     Reply with quote
Regarding the clock line for this eeprom, I constantly see that low level
routines TRISTATE to high impedance when bringing this line high. What is
the reason for this and wouldn´t setting the I/O pin to an output and then
setting it high do the same thing?. Thanks.
PostPosted: Mon Jan 05, 2004 2:42 am     Reply with quote
This allows "clock stretching" by the slave device. This is possible
because the Master does not drive the SCL line high, but instead
it is brought high by a pull-up resistor.
From the i2c spec:
"On the byte level, a device may be able to receive bytes of
data at a fast rate, but needs more time to store a received
byte or prepare another byte to be transmitted. Slaves can
then hold the SCL line LOW after reception and
acknowledgment of a byte to force the master into a wait
state until the slave is ready for the next byte transfer in a
type of handshake procedure".
Here's the CCS code after the (software i2c) Master has transmitted
a byte to the slave device.
0023 BCF 06.1
0024 BSF 03.5 // Bank 1
0025 BCF 06.1
0026 NOP
0027 BSF 06.0
0028 NOP
0029 NOP
002A BSF 06.1 // Set SCL as an input pin
// Here's the loop where they test for clock stretching by the slave.
002B BCF 03.5 // Bank 0
002C BTFSC 06.1 // Test SCL pin. Skip next ins. if it = 0
002D GOTO 030 // If SCL = 0, exit this loop
002E BSF 03.5 // Bank 1
002F GOTO 02B // Jump back to the start of the test loop
0030 ...
