		| Author | Message |
		| rrb011270
				| Using #int_timer2 to on/off buzzer |
				|  Posted: Fri Dec 19, 2003 1:37 am |   |
				| Mabuhay!
 I have a problem with the code below... it would not generate a monotone on my buzzer.. anybody in the forum who can check and review my code.. I plan to generate a 100Hz monotone using interrupt timer2 at PortA4 of PIC18F452.
 The code listed below:
  	  | Code: |  	  | #include <18F452.h>              // Target PIC Microcontroller IC #device  *=16                    // use a 16-bit pointer
 #device ICD=TRUE
 #fuses HS,NOPROTECT,NOWDT        // PIC MCU Configuration
 #use delay(clock=20000000)       // 20MHz Crystal clock speed
 // Configure PortA4 for buzzer output
 #bit BuzzBIT=0xF80.4
 const int tones[] = { 70,74,76,83,88,94,99,105,112,118,126,133,141 };
 int tone_reqd;
 #int_timer2
 void tick(void) {
 static int tick;
 static int toggle;
 if (tick) --tick;
 else {
 tick=tones[tone_reqd];
 toggle^=1;
 BuzzBIT=toggle;
 main()
 setup_timer_2(T2_DIV_BY_4,40,1);
 enable_interrupts(int_timer2);
 enable_interrupts(global);
 tone_reqd=1;
 while (1) ;
 I'll appreciate any help.
 Thank you.
		| Mark
				|  Posted: Fri Dec 19, 2003 8:58 am |   |
				| Didn't look at your code, but RA4 stands out.  That is the first thing I look for when the hardware guys do designed.  They always forget to add a pullup.  Refer to the datasheet if you are trying to drive some device.  You will need to add a pullup resistor or tie one pin of the buzzer to 5V. |  |
		| Mark
				|  Posted: Fri Dec 19, 2003 9:10 am |   |
				| It also look like your frequecy is around 156Hz.
 20000000/4 = 5000000 = internal clock
 5000000/4 = 1250000 = timer2 increments
 1250000/(256-40) = 5787 = timer2 interrupts
 5787/74 = 78 is the 1/2 frequecy
 Now I am not sure what you are trying to drive, but I don't think it is a subwoofer
  That sounds like too low a frequency.  Most piezo's are in the KHz. |  |
		| rrb011270
				|  Posted: Sun Dec 21, 2003 6:37 pm |   |
				|  	  | Mark wrote: |  	  | Didn't look at your code, but RA4 stands out.  That is the first thing I look for when the hardware guys do designed.  They always forget to add a pullup.  Refer to the datasheet if you are trying to drive some device.  You will need to add a pullup resistor or tie one pin of the buzzer to 5V. |
 Based on the data sheet, the RA4 is an open drain output... so I use the buzzer as a pull-up with a diode protection.  I guess this will work coz wen I invoke output_low the buzzer will sound... there is no need for a resistor as pull-up coz the buzzer will serve similar to a resistor...
