Counter for number of RESET
esa
PostPosted: Sat Feb 09, 2008 4:45 am     Reply with quote
Dear users,
I use a external WatchDog device ( MAX6301) to reset the PIC in case of hangUp. So, it's a real reset on the PIN MCLR.
How can I count the number of reset ?
I already do that by setting a PIN (on a PCF8574) as output in my main code.
When the reset occur with the WD ( so without power off ).At the start of my program, I check this PIN.
I increment a counter if PIN =1 and store it in EEPROM.
When a reset occur by power off, the PIN is low, so I don't increment the counter ( it's a normal power off ).
But, now I can't use a PCF8574.
Is it a way by doing this directly with the PIC18F4620 ?
Using a variable, or a PIN ?
I think, it's not possible.
Best Regards
Eric
PostPosted: Sat Feb 09, 2008 8:26 am     Reply with quote
Have you tried using the function Restart_cause()? Use this as one of the first functions in your program and it should give you the reason for restart. On a PIC18F4620 it can give you the following values:
// Constants returned from RESTART_CAUSE() are:
#define WDT_TIMEOUT       7
#define MCLR_FROM_SLEEP  11
#define MCLR_FROM_RUN    15
#define NORMAL_POWER_UP  12
#define BROWNOUT_RESTART 14
#define WDT_FROM_SLEEP   3
#define RESET_INSTRUCTION 0
You should get NORMAL_POWER_UP after a power down or MCLR_FROM_RUN when the reset pin was triggered.
Another solution would be to place a checksum in a global variable. After a reset the contents of RAM are not touched so the checksum should still be there. In case of power down the variable will contain random data. With an 8 bit checksum there is a 1/256 chance the random value equals your checksum, giving a wrong detection. Use a 16 or 32 bit checksum for even better detection rates.
#define MAGIC_BOOT_VALUE  0x12345678
int32 WarmStartDetect;
  if (WarmStartDetect == MAGIC_BOOT_VALUE)
    // Reset detected
    // Normal power up
    WarmStartDetect = MAGIC_BOOT_VALUE;  // Set value for next reboot
esa
PostPosted: Sun Feb 10, 2008 5:05 am     Reply with quote
dear ckielstra,
That's exactly what I need ( and maybe more ). Very Happy
So, thanks a lot, for this informations. Wink
I will use "restart_cause".
Regards
Eric
Case closed
mskala
PostPosted: Sun Feb 10, 2008 9:42 pm     Reply with quote
You can do this by looking in the RCON register. At the beginning of your program, check whether the ~POR bit is clear, that indicated it was a power-on reset. (If it is clear, you have to set it in software). I did this for a project at work with the 18LF4520, and the 4620 is equivalent for this. Check the datasheet.
PostPosted: Sun Feb 10, 2008 11:40 pm     Reply with quote
That's what restart_cause() does. It reads the RCON register, and it
also sets the bits = 1, so it's ready to detect the cause of the next reset.
Here is the .LST file for the 18F4620 with vs. 4.066:
........ value = restart_cause();
00018:  MOVF   RCON,W
0001A:  ANDLW  0F
0001C:  BTFSS  RCON.RI
0001E:  MOVLW  00
00020:  BSF    RCON.BOR
00022:  BSF    RCON.POR
00024:  BSF    RCON.RI
00026:  BSF    STATUS.OV
00028:  BSF    STATUS.N
0002A:  MOVWF  value
D-Kens
PostPosted: Mon Feb 11, 2008 2:08 am     Reply with quote
Remember to use "restart_cause()" at the very beginning of your main, even before all the setup commands, cause some of them are likely to change the value (so I read).
