alex Guest
variable pic16f628a |
Posted: Sat Feb 16, 2008 1:20 pm |
Hi, i need help for a little problem.
My source code:
#include<16f628a.h>
#fuses NOWDT,NOPROTECT,PUT,NOLVP,MCLR,INTRC_IO
#use delay(clock=48000)
#use fast_io(b)
#use fast_io(a)
int duty;
duty= 1;
setup_oscillator(OSC_48KHZ);
set_tris_b(0xF7);
output_low(PIN_b3);
output_high(pin_b3);
delay_ms(duty);
output_low(pin_b3);
delay_ms(20);
Easy? No, because I have a problem. when I use duty=1 I have a rectangular wave of 1.5 ms Hi and 20 ms low.
If i use delay_ms(1) I have 1ms Hi, if I use delay_ms(2) I have 2ms Hi., but with delay_ms(duty) I can´t create the same value of duty=x.
So, a variable int is wrong? |
Posted: Sat Feb 16, 2008 3:26 pm |
The problem is likely caused by your very low clock speed of 48 KHz.
The instruction cycle frequency is 1/4 of that, which is only 12 kHz.
CCS uses software delay loops to create the delays in the delay_ms()
function. With a 12 KHz instruction clock, there are 12 instructions per
millisecond. "Branch" instructions take two cycles. I haven't looked at
the .LST file, but I suspect that the CCS library code for delay_ms() just
doesn't work very well at low clock speeds. |
alex Guest
Posted: Sat Feb 16, 2008 3:50 pm |
But, PCM programmer, the instructions delay_ms(1) e delay_ms(2) are working well. I see 1.1 ms hi e 2.1 hi.
The instruction delay_ms(duty) , where duty is a variable int that is not working.
Is it not possible that i am using a wrong variable? |
Posted: Sat Feb 16, 2008 4:00 pm |
The problem is that the delay_ms, using a _variable_, is much more complex code, than that using a fixed value. For the constant, the compiler inserts the instructions needed to get as close as it can the the specified time. For the variable version, it has to have a loop, and count down the variable. The minimum loop time is about 10 instruction times, and the 'step size', is about 15 instruction times. The delay_ms code, for variables, is just not able to cope with times where there are so few instructions per loop. I suspect you will find that the arithmetic, actually goes 'haywire' internally, if one mSec, is less than the shortest available loop time...
At this clock rate, a variable loop, is beyond the ability of the code to deal with.
alex Guest
Posted: Mon Feb 18, 2008 8:29 am |
Well, I gave up of delay. I used a instruction "for" and I did 1ms hi and 20ms low.
The problem is that I can´t change the values of duty cycle.
The variable int of instruction "for" doesn't increase in decimal.. I can´t increase or decrease the duty cycle.
Are there solutions for that? |
Wayne_
Posted: Mon Feb 18, 2008 10:46 am |
Something like
#include<16f628a.h>
#use fast_io(b)
#use fast_io(a)
#define PERIOD 20
int duty;
duty= 1;
set_tris_b(0xF7);
output_low(PIN_b3);
int n,i;
for(n=0; n<duty; n++) {
// Insert dummy code to create required delay or use another loop
for(i=0; i<10; i++) {}
output_low(pin_b3);
for(n=0; n<(PERIOD - duty); n++) {
duty = 0 to PERIOD
the low period will be slightly out due to the PERIOD - duty calculation. This can be corrected by changing the internal for(i= loop.
There is still a problem with this.
If duty = 0 you will still get a low pulse.
If duty = PERIOD you will still get a high pulse.
If the delay (for) routines are too slow then you will not be able to get the desired 1ms duty. You do the math. |
