Gerd
Any experience with Slave I2C |
Posted: Wed Dec 17, 2003 3:44 am |
Hi everyone,
I'm seeing a I2C problem for the last couple of days.
I'm using 16f876 as master and 16f872 as slave processor. The ccs version is 3.180 and the Slave code is from Ex_slave.c
Now everything works fine on the workbench, I read analog data from the slave every 100ms. When I install it in a noisy (electrically) environmet communication stops aftre a few minutes.
The Master is still sending clock, but SDA is low, forever, Slave pulling it down.
I assum the Slave gets a spike, calls the interrupt routine and than gets no more data antill the master sends a new telegramm.
The processor is still doing the main loop, so it is not crashed.
I also can't get the I2C working again. Tried restart_cpu, SDA is low!
Any idea if it is a spike problem and how I can solve it. I don't mind if the I2C is looked for a few secunds, as long as I can detect the crash and restart it.
Slave code:
#INT_SSP
void ssp_interupt ()
BYTE incoming;
if (i2c_poll() == FALSE) {
if (fState == ADDRESS_READ) { //i2c_poll() returns false on the
i2c_write (buffer[address]);//interupt receiving the second
fState = NOTHING; //command byte for random read operation
else {
incoming = i2c_read();
if (fState == NOTHING){
fState = CONTROL_READ;
else if (fState == CONTROL_READ) {
address = incoming;
fState = ADDRESS_READ;
else if (fState == ADDRESS_READ) {
buffer[address] = incoming;
fState = NOTHING;
Posted: Wed Dec 17, 2003 12:58 pm |
Quote: | The processor is still doing the main loop, so it is not crashed.
Any idea if it is a spike problem and how I can solve it. I don't mind if the I2C is looked for a few secunds, as long as I can detect the crash and restart it. |
On a 16F872, the reset_cpu() function jumps to rom address 0.
It doesn't do a hardware reset.
You could try some experiments. If you can detect when your problem
occurs, then you can force a WDT reset. To do this, enable the WDT in
the #fuses statement, and put restart_wdt() in the appropriate locations
in your code, so it won't normally timeout. Then, when you want to
cause a WDT reset, do this:
if(problem_occurred)
while(1); // Wait here until WDT causes a reset
